Shane (guest)
Guest
Posts: n/a
If the crank sensor is damaged, will it not allow the automatic transmission to shift gears especially fourth it seems to retard the acceleration. Please help
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-21-2013, 09:33 PM
No, you will need to check codes in both the DME and the EGS systems to see why you aren't shifting into 4th gear.
- Kerry
