harrygee (guest)
Guest
Posts: n/a
1998 318i, brake lights not working. tester shows power to contacts and harness but no lights including third-pastel shelf- light. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-22-2013, 05:23 AM
Nick at Pelican Parts's Avatar
The brake light signal goes through the check control module. Check the input from the brake light switch at pin 9 and the output at pins 8 and 14. If it is going in and not out, you will need a check control module.
- Nick
