Mike (guest)
Guest
Posts: n/a
My dash oil light will not lit at all when the ignition is turned over. What would cause this on a e36 m3? Oil pressure switch? It's not the bulb.
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-04-2014, 12:44 PM
Nick at Pelican Parts's Avatar
Is it on with the Key in the ON position? Could be a bad signal. I would scan the cluster for faults, there may be a fault code stored.
- Nick
