Beamer328 (guest)
Guest
Posts: n/a
Hello Auto
I have a 1998 BMW 328 IS. The driver side low beam bulb won't work. I checked that there is power going to the plug. I even removed the bulb and placed it into the passenger side and discovered the bulb to be good. Is there some place that this plug can be purchased?
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-17-2014, 05:41 AM
Nick at Pelican Parts's Avatar
Give our parts specialists a call at 1-888-280-7799 and they can help figure out which part or repair kit you need.
- Nick
Low Beam Not Working on Driver's Side
This is not an issue having to do with purchasing some sort of kit or part. I've already tried many things such as swithing bulbs with the passenger side and checking the low beam module. I've also replaced the plug that goes to the passenger low beam side too. There is power going to the plug.
Old 01-17-2014, 09:52 AM
