Guest
Posts: n/a
I didn 't know that you can get fault codes for a problem such this.
For the problem with the different temperature I described, it 's also a door issue? And a last one, about the function of the dual zone clima. When I press the AUTO mode the fan speed is compute by the clima itself. If for example I raise only the driver 's side temperature, the fan speed increase automatically. If I raise only the passenger 's side temperature, the fan speed stays the same. It doesn 't increase its speed. __________________ This post was auto-generated based upon a question asked on our tech article page here: |
If a system has a control module, there is likely fault tolerance. Checking for these codes is a good place to start.
I would address one issue. Attempting to advise you on diagnosing two would be tough. Go for the dual zone issue, check for faults, run a test on the mode doors. You may find the solution to both issues in the same place. - Nick |
