Jacob B. (guest)
Guest
Posts: n/a
1997 e36 318i won't start cranks and try to start with oil in cylinders but think I'm not getting fuel to the plugs. I swapped the pump and it runs when I crank. There are no fault codes and I have spark.
http://youtu.be/hPvANgtFpqk
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-09-2014, 12:10 PM
Nick at Pelican Parts's Avatar
You'll need to check fuel pressure and injector pulse to be sure one of them is missing. I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and pressure fuel, volume and quality. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick
