-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Question on BMW 3-Series E36 O2_Sensor (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/805470-question-bmw-3-series-e36-o2_sensor.html)
Otto (guest) 04-09-2014 12:11 PM
Hello. Just had to replace a faulty injector on my 325i but the engine is still rough on idle before evening out. The mechanic mentioned that the oxygen sensor was probably contaminated - will this wear off or I will I need to clean or replace the sensor now ? Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 04-09-2014 12:11 PM
O2 should not cause rough running on one cylinder. I would check for a misfire on that cylinder, spark, fuel, compression.
- Nick
