Otto (guest)
Guest
Posts: n/a
Hello. Just had to replace a faulty injector on my 325i but the engine is still rough on idle before evening out. The mechanic mentioned that the oxygen sensor was probably contaminated - will this wear off or I will I need to clean or replace the sensor now ? Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-09-2014, 12:11 PM
Nick at Pelican Parts's Avatar
O2 should not cause rough running on one cylinder. I would check for a misfire on that cylinder, spark, fuel, compression.
- Nick
