WestSideWolf (guest)
Guest
Posts: n/a
Hello, I have a 1988 BMW 325i Convertible
I noticed when I turned on the car its temp gauge would jump from cold to hot with out even being on for all of five mins.
So what I did was I replaced the thermostat, however it still occurs so I ordered new coolant sensors and etc
But Im still unsure because it idles rough like a smokers cough before it never had any issues. So I'm wondering what it could be.Thanks.
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-25-2014, 12:37 PM
Nick at Pelican Parts's Avatar
Sounds like you have an engine misfire. I would guess the coolant gauge issue is a separate issue.
I would start by checking the DME for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
