Guest
Posts: n/a
I have an 2000 323i, my A/C blows warm air from center vent, hot from defrost, and hot from foot vent. Middle vent wheel is set to 3 blue dots and A/C is turned on, and set to 59 degrees. This car has a new FSU, a new water valve, and new R134a refrigerant professionally evacuated and installed to 1.6 pounds or 1 pound 10 ounces. Can you tell me which part I need?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Does the system blow cold from any vent? Is the compressor turning on? Is the heater control valve blocking coolant flow when the A/C is ON?
- Nick |
