Luke (guest)
Guest
Posts: n/a
I have an 95 325is that idles rough when it warms up. When you come to a stop light it will drop to less than five and back to 1k. have to keep foot on gas to not stall. Also does this when you turn on headlights or fan switch to max. Will also die when doing hard turn into parking spot at low speed if you arent careful and keep your foot on the gas. Have been told maybe vacuum leak or ICV needs cleaned.
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-08-2014, 06:41 PM
Nick at Pelican Parts's Avatar
Have you checked the charging system? Does it run OK once the RPM us raised?
- Nick
