-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Turn Signal Issue (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/815066-turn-signal-issue.html)
87 BMW 325 06-07-2014 05:31 PM
Turn Signal Issue
Hello all. I have an 87' 325 (base model) that indicates that I have a bad connection. My left turn signal works great, but when I turn on the right turn signal, the inside indicator blinks really fast. I visually inspected the rear blinker and it works great. The problem is with the front right blinker indicator.
I have replaced the front bulb and even switched it with the left front to make sure that it was not a bad bulb that I replaced. I did this with the fuses also and nothing worked. I know that the fuses and the bulbs are good.
I'm thinking that I may need a new front light assembly. Any suggestions before I spend my cash?
