Thanks for your reply.
Went to workshop and did the diagnose and it appears O2 SENSOR FAULT CURRENTLY PRESENT. I bought the BOSCH 4 wire o2 sensor and now the foreman said the wire length is different with the currently plugged on my car. Will the wire length be a problem here? Car is 94 325 model and only has 1 o2 sensor. Is this correct? On the wire's length, can I just plug it in without doing any alteration on the length? Thanks in advance. __________________ This post was auto-generated based upon a question asked on our tech article page here: |
If it is a little longer, it should be OK. Just be sure the wiring is routed safely.
- Nick |
| All times are GMT -8. The time now is 02:40 PM. |
