hi i have recent the problem withbmw320d 2004 when u strat car sounds ok then try to drive car misfire brake stearing then car beeps like some worning and in same second with this beep signal car runns fine..?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Is the check engine light ON? I would start by checking the vehicle for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick |
| All times are GMT -8. The time now is 08:50 AM. |
