don (guest)
Guest
Posts: n/a
hi i have recent the problem withbmw320d 2004 when u strat car sounds ok then try to drive car misfire brake stearing then car beeps like some worning and in same second with this beep signal car runns fine..?
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-07-2014, 06:07 PM
Nick at Pelican Parts's Avatar
Is the check engine light ON? I would start by checking the vehicle for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
