Vick (guest)
Guest
Posts: n/a
Hello, I have a 2006 bmw 323i. The problem seems to be that when I fill up the tank with gas I drive for a bit and it's fine. But after awhile when I pull up at Red lights or stop signs it will start to shake a lot and than turn off. I'm not sure if this is the fuel pump or something else. I played around with the coils and sensors and it worked fine for a bit but now it's back at it. I changed 2 sensors and 2 coils on it. Any idea what it may be?
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-05-2014, 07:00 AM
Nick at Pelican Parts's Avatar
Is the check engine light on? Sounds like an engine misfire. I would check spark, fuel and compression on all cylinders.
- Nick
