In the shop at Pelican
Jared at Pelican Parts's Avatar
Fuel pressure Regulator?
Does anyone know the procedure for testing the fuel pressure regulator?
Old 02-28-2003, 01:23 PM
I may me missing the point.
But wouldn't you put a Fuel Pressure Guage in-line...
This would only be a check, and not a test of the regulator it self.
'84eta
BMW CCA
Old 02-28-2003, 05:01 PM
hey jared
do you need one, i hvae a spare
take it easy
jeff
Old 02-28-2003, 06:32 PM
If you want to know how much fuel pressure the regulator is maintaining, yes, you'll need a guage inserted in the fuel line. (just before the fuel rail is a good place).
But, if you only want to know if the regulator is functioning, disconnect the vacuum hose from the regulator itself. If the engine is idling when you do this, the rpm should go up noticably. Reconnect the vacuum line and the engine RPM should return to normal.
There are some owners that say they don't notice a change in the RPM when they disconnect the vacuum line, yet their regulator is functioning correctly. So, to that end .....er....ah....Idunno...
Try it and see what happens...
Dan
'86 325
'97 328is
'03 V-Max
Old 03-03-2003, 07:37 AM
I think mine might be on the way out. I have been noticing a weirds thing where my car acts like it has vapor lock when you start it warm, it will stumble under load for a few seconds, then come back to normal. I'm suspecting the regulator.
Old 03-03-2003, 10:05 AM
Yes, pianodan is correct.
Now I remember checking my regulator when it died.
That was after replacing all my fuel lines after they blew off/ruptured
from the regulator catastrophacally failing.
'84eta
BMW CCA
Old 03-03-2003, 05:16 PM
Originally posted by Jeff at WallWerks
hey jared
take it easy
jeff
Jeff, how much do you want for it?
Old 03-07-2003, 03:25 PM
