-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Best way to get an LSD into the diff? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/84221-best-way-get-lsd-into-diff.html)
Wayne 962 10-14-2002 10:09 PM
Hi folks. I would like to do a project on LSDs for the new BMW book I'm working on. Trouble is, I don't know too much about the E36 LSDs and what's available, and for how much. Any good sources of info out there, or does anyone want to share their knowledge?
-Wayne
Jared at Pelican Parts 10-15-2002 03:23 PM
The E36 LSD is designed to be replaced as a unit. Essentially, you repalce the entire diff. Korman Autoworks has a 4:10 ratio LSD, that bolts right in. I know Quaife makes some pretty good units as well. I think you can even take an auto diff from the E36 automatic, and use the carrier gears (3:91) in a LSD diff.
RDW DEV 10-16-2002 02:02 AM
What's an autodiff?
Dave at Pelican Parts 10-16-2002 06:58 AM
I think he means the differential that was used with the automatic transmission. Same as the manual, but a different ring and pinion ratio.
--DD
Jared at Pelican Parts 10-16-2002 09:20 AM
Exactly Dave. Sorry I wasnt clear enough
