Brandon (guest)
Guest
Posts: n/a
I have 96 328i, as theas tightening the bolts on the water pump they broke. So I'm wondering how do I remove those screws if they are attached to the block?
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-19-2014, 04:20 PM
Nick at Pelican Parts's Avatar
Remove the water pump. If there is enough bolt sticking out, unscrew them using vise grips. If not, you will have to drill the bolts and use an extractor to remove them.
- Nick
