Tommy (guest)
Guest
Posts: n/a
I have a 2000 BWM 323ci..... When I attempt to start the car the starter does not turn over. The battery is new...... The dash lights and the headlights strobe on and off and there is a click click click sound....... Please advise.........
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-05-2015, 05:34 AM
Nick at Pelican Parts's Avatar
Sounds like a voltage supply problem. I would test the battery to start, even though it is new. Then voltage drop the battery cables and connection at the starter.
- Nick
Check to make sure your grounds are good too. I would remove any grounding bolts and clean the attachment points.
Old 02-07-2015, 11:12 PM
