PK (guest)
Guest
Posts: n/a
One trick on putting on the small sump containing fluid. Take two old pan bolts and cut the heads off. Screw them in at each end of the tranny housing, and now you have removable guide pins. Prevents the sump from moving around while you are getting the regular bolts in. After you get the sump on, simply unscrew the old headless bolts, and replace with the regular bolts. Cheers!
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-17-2015, 04:46 AM
Nick at Pelican Parts's Avatar
Thanks for sharing your installation process and experience. These type of comments add so much to the Pelican tech community.
- Nick
