Guest
Posts: n/a
I have a 96 318is coupe. Both windows wont roll down and the anti pitch no longer functions. I press on the window switch and only clicking is heard. I managed to drill out the rivets from the driver side door and there seems to be a stop when i press the button for it to roll up. I hold the motor in my hand and the gear works, but it seems to have an infinite "down" but a limited "up". I can't figure out what could be the problem. The motor works while its held in my hand but it has an infinite "down" and a limited "up" and the anti pinch is not working.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
It sounds to me like what you are saying is, when the motor is attached to the regulator, it does not work. When removed it does. This could be a motor that cannot handle the load of the window or a regulator that is jammed. Does the window move up and down smoothly when the motor is removed? If you move it manually?
- Nick |
