Guest
Posts: n/a
Ok so i just checked my fuses all the fuses except for 1 or 2 of the ones in column 31-46 and i changed those but none of the fuses in any other column would work when tested. So i swapped 1 with another one that knew for fact works and it didnt work there. But it did when i put it back. I was checking fuse because my window and and sunroof no longer work. The window regulator will work when its reset until its dropped all the way down and it wont go up at all. Same with the sunroof but it wont open much then it stops. I did change the motor on both and did change the regulator on the window. So i was thinking the problem is all related? Since it all went out about the same time.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The issues could be related, but I would focus on diagnosing one component, if they are related you will find the cause of all issues.
When the windowwill not raise, does it have power and ground when commanded to? - Nick |
Yep
Yes the window is getting power and is grounded. By the way it is a 1994 bmw 325is
