sucishifter69 (guest)
Guest
Posts: n/a
I have a 1995 521i sedan.I put 2 new 205/55 tires on front to get more rake. I have 205/60 on rear. After a month or so the yellow warning light in between speedo and tach came on and stays on. What to do? can I remove main ignition fuse fore a minute and reconnect
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-09-2015, 06:23 AM
Nick at Pelican Parts's Avatar
Which light? Check engine or ABS? The tires may have hit some wiring if ABS.
I would start by checking the vehicle for fault codes. If multiple systems are not working properly, fault codes will be set. This will be your best bet when diagnosing.
- Nick
ABS light
Old 07-10-2015, 03:40 AM
