Exhaust Tip Extensions
I am trying to put on chrome exhaust tips on my 1998 323ic. The two are diferent sizes. Is this correct? Are there any suggestions on how to put these on? There are also screws in the bottome of each tail tip. What are these for?
Thanks,
Mike
Old 11-15-2002, 08:38 AM
Yes two sizes are correct. If you look at your stock exhaust, there is a shorter tip and a longer tip. You'll see once you look. These just slip over them and that little screw goes on the bottom and is used to hold on the chrome units. Slip 'em on, screw 'em down and that's it.
About a 2 minute job. Not even a 1 beer or wine job. Less. (Everything has it's pros/cons.)
Mike
'98 328iC
Nashville (w/ stock black tips)
Old 11-15-2002, 10:43 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I just ask polietley that you not install once of those ricer fart can exhausts, =)
Old 11-15-2002, 10:44 AM
Can I get an Aaaaa-Men?
A-men brotha!
Old 11-15-2002, 10:47 AM
The screw has a square nut that attaches on the inside if the exhaust tip. How do I tighten it?
Old 11-16-2002, 07:22 AM
