Bob (guest)
Guest
Posts: n/a
Nick, You didn't mention if there was a bolt tightening pattern to follow for each of the exhaust manifolds, nor did you mention the torque setting for the bolts. A 6mm bolt nominal torque is 10 NM 7ft-lbs is this the value for an E36 exhaust?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Exhaust Manifold Replacement
Old 10-29-2015, 04:56 AM
Nick at Pelican Parts's Avatar
I don’t have that info.
I would grab a repair manual. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799.
- Nick
