Electrical (guest)
Guest
Posts: n/a
I have a 1999 528i Wagon with electrical problems: electric windows work sometimes, no directional signals both the actual lights as well as the related dashboard lights, dashboard is un-lit when headlights are on, no radio, no heated seats, no AC, no emergency lights. There may be other issues, as well.
Battery is dead at the moment. It's a fairly new battery, so I'm assuming that the dead battery is related to the current electrical issues.
Swapping out the ignition switch did not fix the problem.
Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Troubleshooting Electrical Problems on Your BMW
Old 01-06-2016, 04:57 AM
Nick at Pelican Parts's Avatar
The general module may be at fault. I would start by checking the vehicle for fault codes. If the GEM is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
