thompson1295 (guest)
Guest
Posts: n/a
Hi, I have a 1991 E30 and I just replaced the fuel pump and fuel filter. The fuel pump is making a lot of noise and will get to certain speed and the gas pedal will have no affect. Also looking for the transfer pump.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing the Fuel Pump & Fuel Level Sender on Your BMW
Old 01-21-2016, 05:33 AM
Nick at Pelican Parts's Avatar
Could be an issue with the fuel pump. Possible restriction or wiring issue. I would perform a fuel delivery system test. Check fuel pressure, volume and quality. Transfer pump is in-tank.
- Nick
