-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Question on BMW 3-Series E36 O2_Sensor (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/901319-question-bmw-3-series-e36-o2_sensor.html)
Jack (guest) 02-05-2016 05:39 AM
The repair shop did memtion that the pump pressure was less than usual, but not below limt, but How come that when i put the pedal to the floor the car suddenly picks up acceleration.
I must add, that as the car heats up, at a certain point after 30min of nominal temperature, like a switch is tripped, the problem dissapears as if nothing was wrong. I'm doubting in electrical more than mechanic. What do you think.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3 Series (E36) Oxygen Sensor Replacement
Nick at Pelican Parts 02-05-2016 05:39 AM
If it doesn't warm quickly, the thermostat is faulty. If pump pressure is under spec, it is bad. Has to be repaired.
- Nick
