Jack (guest)
Guest
Posts: n/a
The repair shop did memtion that the pump pressure was less than usual, but not below limt, but How come that when i put the pedal to the floor the car suddenly picks up acceleration.
I must add, that as the car heats up, at a certain point after 30min of nominal temperature, like a switch is tripped, the problem dissapears as if nothing was wrong. I'm doubting in electrical more than mechanic. What do you think.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3 Series (E36) Oxygen Sensor Replacement
Old 02-05-2016, 06:39 AM
Nick at Pelican Parts's Avatar
If it doesn't warm quickly, the thermostat is faulty. If pump pressure is under spec, it is bad. Has to be repaired.
- Nick
