325IS stiff getting into reverse (man tranny)
My '89 325 IS is quite stiff passing the reverse interlock. that is, there is no problem getting _into_ reverse, it's stiff moving out of the neutral position over to the left. No problem sliding it forward into reverse.
Is this normal? I installed a UUC short shifter and took it out, because it took both hands to pull the shifter over out of neutral. I have replaced all the shifterbushings and the reverse light switch, thinking it might be binding up. No luck. any ideas?
steve soar '76 911S in process of being resurrected |
In the shop at Pelican
This may be a stupid question, but have you checked the fluid level in your gearbox? Low fluid can cause sticking. How many miles are on the clock? Maybe a bad synchro hub?
just put in fresh MTL
I put in the redline just in case, does make the box shift better, but didn't help reverse much.
And its not a problem getting it into gear. It's just the moving to the left coming out of neutral. (Must be pushing in a detent spring) Acutally getting it into gear is no problem. 125K on the box. thanks for any help,
Maybe the new short shifter is misadjusted?
may sound stupid but ive had alot of trans problems with my 325 when it started to go bad it wouldnt go into any gear other than 4th 5th and reverse but when my motor mounts when bad in the car and the motor and trans slid forward an inch it was hard to put into gear get out of gear and do anything with maybe you should check the motor mounts
