-If its possible to swap a M3 differential into a '98 328is 5-spd w/o major complications... If so do you have any posts you could direct me to describing this, or to anyone who has actually done it?
thanks |
I just posted your question on the Puget Sound Chapter BMW BBS. I'll have something for you tomorrow. I an assuming your locking for a LSD?? If you looking for a different final drive ratio (3.23:1 va 2.93:1) you'll need a 97 or later.
Keith
74 914 2.0 (sold) 96 328is |
thanks jenmc.
yes, LSD and if its possible to keep the ASC hooked up as well. Kutch |
Yup, its possible. 3:23 came in auto9 95M3 and then all 96-99 M3 5speeds. Just use your flanges off your 2.93
PS. Let me know if youre getting rid of that 2.93 diff
1993 325IS Turbo T3/T04e M3 Cams |
ya',
I'm looking at a 96 M3 diff w/ 60K miles on it. As soon as I feel out the situation & condition I'll let you know. Kutch |
My CCA friends said yes. The 96 M3 has the same ratio (2.93) as your 328. Go with one from 97 or newer.
Keith ps - I thought I read somewhere that the diffs out of the automatics wouldn't work in manual cars.
well, seeing that I have a 5-spd I will not be considering any diff out'ta a auto M3. (auto M3? isn't that like, wierd)?
Youll see a good difference from your 2.93 to a 3.23
Ya know, Ya gotta' wonder why someone would be selling the diff out of thier M3? ? is there something better?
3.38 or 3.46 diffs are out there also , along with custom ones. It all depends on how crazy you wanna get.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process. 97 328is Black on Black 5 speed Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler |
1993 325IS Turbo T3/T04e M3 Cams Last edited by Geno325is; 02-26-2004 at 03:58 PM.. |
what?......ya didn't like that?
