Tania (guest)
Guest
Posts: n/a
hi I have a 320 e30BM my car just died last week and I replaced the cambelt but now my car does not want to start there is power but the ignition is just turning what can I do
This post was auto-generated based upon a question asked on our tech article page here: BMW E30 3-Series Timing Belt Replacement (1983-1991) | Pelican Parts DIY Maintenance Article
Old 06-15-2016, 12:15 PM
Nick at Pelican Parts's Avatar
I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume, quality and engine compression. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick
If you had to replace the timing belt due to it breaking, there is a good chance that you bent the valves and they will no longer close. Do a compression check to see if your valves are closing properly.
Old 06-19-2016, 09:41 PM
