-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Another E30 Idle Problem (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/91949-another-e30-idle-problem.html)
jamesthevaliant 12-23-2002 06:45 PM
I have seen a few posts in reference to E30 idle problems, and unfortunatley, I am adding one more. I will try to be specific......and hopefully I will get some insight. Thanks for your help.
I have a 1990 325is. I live in cold NJ...and the motor will idle very roughly when started cold in the morning or after sitting 3 or 4 hours. If allowed ample time to warm up, the car will accelerate properly. When completley warm, the engine will run strong, and accelerate well, but still maintains a very erratic and lopy idle when resting. If driven cold, the motor will bog out while trying to accelerate until it is warm.
In the past three weeks I have done the following: new disributor cap, rotor, ignition coil, bavarian autosport plug wires, plat+4 plugs, k&n panel air filter, fuel filter....I have tested the idle control valve with a multi meter, and it is in accordance with the Haynes manual.
WHAT IS MY NEXT STEP HERE? IS THIS A FUEL PROBLEM? DO I NEED NEW INJECTORS? I AM JUST LOOKING FOR A FINGER IN THE RIGHT DIRECTION. THANKS FOR YOUR ADVICE!!!!
JIM
Jeff at WallWerks 12-23-2002 06:48 PM
Hi there:
No offense dude, but I live in Arizona and mine idles pretty lopey as well. I have heard from a couple of BMW specialists that
"they all do that" I have done the same stuff you have and am about to try injectors too. I don't seem to remember these cars
idling this way when they were new.
good luck
jeff
jamesthevaliant 12-24-2002 01:53 PM
well, I can't give up!... actually I was just reading some old posts, and saw someone mention that Bosch platinum+4 plugs do not work well in the M20 so I will try changing them. I would appreciate any other advice though........
jamesthevaliant 12-24-2002 01:54 PM
Jeff, Let me know if you change your injectors.....
daves325 12-24-2002 06:40 PM
James....I just read a blurb on a guy that has the same problem..(Illl give you the link below for a good e30 forum)...and he basicallly took the Idle control valve off, cleaned it with carb spray, blew it out with compressed air & it works great!
I know you tested it for electical complinace, but they do have a mechanical aspect as well.
Try it.
Dave.
http://bimmer.roadfly.org/bmw/forums/e30/forum.php
dylan 12-25-2002 05:29 AM
i just wanted to add that i live in VA and mine doesnt do it yet but if it does atleast i know im not the only one
Wayne 962 12-25-2002 03:52 PM
The lopey idle is typically caused by either a mixture problem or a vacuum leak. I would suspect vacuum. Change all your vacuum hoses (pretty cheap to do, and they are probably old anyways), and double check the vacuum levels. A small leak will only show up at idle - disappearing when running full speed...
-Wayne
Jared at Pelican Parts 12-26-2002 07:48 AM
James,
A few things,
First, get rid of the Platinum 4's, they do not work all that good in the M20 motor. I put some in my 325is and it actually caused a lopey idle.
You also will want to check that you have a good seal between the oil cap and the valve cover, and also the valve cover gasket. Even loose valve cover nuts can cause this.
Check the intake boot for cracks. It's pretty common to see these boots drying up and start cracking. When the cracks develop, they cause all sorts of problems.
Check the metal fittings on the sides of the throttle body that operate the power brakes. These are press-fittings and can work themselves loose over time. Just a dab of RTV around the fitting and it should be ok.
Wayne 962 12-26-2002 09:51 AM
Right-o, I think that the platinum plugs are the wrong temperature range for that car anyways...
-Wayne
Jeff at WallWerks 12-26-2002 09:57 AM
jared:
I heard that just the garden variety NGK plugs work the best in a 325i, what do you run in your car?
jeff
Jared at Pelican Parts 12-26-2002 10:00 AM
Right now I am running the single electrode Bosch Platinums and they work great. I took them out the other day during a valve adjustment, and they had almost no buildup on them at all.
jamesthevaliant 12-27-2002 10:19 AM
Jared, Wayne,
I have changed all of the hoses coming off of the throttle body, and the intake boot. I also took dave325's suggestion about cleaning out the icv with carb cleaner, but that did not help. I will try changing the spark plugs today and let you know if that helps. However, the problem seems to have gotten worse. The car smells very rich and now bogs out throughout the rev range until warm.
As far as vacuum hoses go, how many do I have? I have found and replaced 2 today....one from the fuel pressure regulator to the intake manifold, and one below the throttle body. Where are the others?......and how do I check the vacuum levels?
Jim
Wayne 962 12-27-2002 10:50 AM
Vacuum hoses - you should be able to see all of them from the engine compartment. If they aren't fuel hoses, then they are vacuum hoses. Some are special BMW hoses that you need to order, but most are regular 8mm or 10mm vacuum hose.
You should check the mixture of the car, and also see if it's pulling any fuel injection codes. Use this technical article as a guide:
http://www.pelicanparts.com/bmw/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm
Hope this helps,
Wayne
Jared at Pelican Parts 12-27-2002 10:51 AM
There is a vacuum hose going from the valve cover to the throttle body. That is the other vacuum hose from which leaks are pretty common. You might also want to check the hoses that go from the throttle body to the brake booster. Sometimes the little metal grommets that hold them in the throttle housing become loose, causing leaks. Just pull them out, put a little RTV around them and push them back in.
From what you are describing now, it sounds like this could be a bad oxygen sensor. Check the connection for the O2 sensor, is it loose? If the connection is ok, the car smells rich, and bogs down till warm, this could be an indication that the O2 sensor is going bad. They have a element inside them that heats up by electrical current, normally, when the o2 sensor is operating perfectly, it warms up, and it sends the correct signal to the OBC. Now, if the O2 sensor is failing, it's possible that this heating element is broken, and it does not function correctly until the exahust has heated up to normal temperature.
This would also account for an erratic idle as well, due to the inability of the sensor to detect the fuel/air mixture, and send the correct signals to the OBC.
Another thing to check is the valve cover gasket and the oil filler cap. If it is old or cracked, it will allow air to leak, and your engine will not run correctly. The system needs to be in total vacuum.
To test the O2 sensor you will need to have a digital voltmeter. You can use a analog one, but I've found that in cases like this, analog units are not sensitve enough to read the types of voltage fluctuation put out by the sensor.
That said, here's what you do. Start the engine and let it idle for a bit. take the oil filler cap off to simulate a a lean running condition. Next, unplug the O2 sensor from it's connection on the passenger side, close to the firewall. Just look at the exhaust manifold, find the sensor, then follow the wire back to it's plug. Once unplugged, you will notice there are four wires in the loom. With the engine running, check the voltage between the terminals. It should be fluctuating, if it is not, this indicates that the sensor is bad.
jamesthevaliant 12-27-2002 11:31 AM
thanks guys....I will try these things and let you know:)
Jared at Pelican Parts 12-27-2002 03:24 PM
Here are some pics to help.
In the throttle body pic, the arrows point to the small metal grommets that press-fit in, and can become loose.
http://forums.pelicanparts.com/uploads/Mvc-043s.jpg
In this pic, I am looking down over the exhaust manifold on the passenger side of the engine.
http://forums.pelicanparts.com/uploads/Mvc-044s.jpg
gr8330 12-28-2002 07:39 PM
Originally posted by Jeff at WallWerks
Hi there:
good luck
jeff
Mine also...and been told the same thing.
Jeff at WallWerks 12-28-2002 07:51 PM
I agree with the oxygen sensor thing. Changing that on my car cured about 80% of the idle issue and some of the midrange flat spot I had.
Am going to go over the hoses with fine tooth comb, change plugs, etc
and upgrade the injectors when I have the $$
good luck
Wayne 962 12-28-2002 10:32 PM
Gee, I could point you to an o2 sensor replacement article, but...
-Wayne
mcanales 12-29-2002 08:03 AM
Jared, Somewhere above about ten messages up you mentioned that you did a valve adjustment. This is on my next to do list. I already have the valve cover gasket. I have read the bentley manual several times, was this an easy adjustment? I have a slight tapping and it's driving me nuts.
jamesthevaliant 12-29-2002 08:24 AM
changed the plugs to single electrode bosch platinums.....big difference when the car is warm, but it still exhibits the same symptoms... O2 sensor and valve cover gasket are on their way and I will install them on tues. I'll let you know.
Wayne 962 12-29-2002 09:02 AM
Valve adjustment - our latest addition to the tech article pile:
http://www.pelicanparts.com/bmw/techarticles/E30-Valve_Adjust/E30-Valve_Adjust.htm
The procedure is not difficult at all!
-Wayne
Jared at Pelican Parts 12-30-2002 03:21 PM
One other things to check,
Coolant temp sensor, believe it or not, this sensor does affect the operation of the OBC, and can cause the idle to go crazy.
Did you check the resistance between the terminals on the Throttle Switch? It is directly below the throttle housing.
Wayne 962 12-30-2002 10:14 PM
The valve adjustment shouldn't take you more than an hour to do...
-Wayne
jamesthevaliant 01-13-2003 05:10 PM
Sorry for the delay... I went to Miami for a week, and now I am back home in cold dirty jersey!
I changed the o2 sensor, and every last vaccuum hose... and I can definatley feel a difference, but the symptoms are still there: it hesitates/ bogs out when it is cold (25F in the morning) runs great when warm...... but with a rough idle.
Coolant temp sensor...valve adjustment......huh?..... keep making suggestions.
I figure that if I slowly replace or adjust every part of this motor I will eventually have a happy BMW.
By the way, I just ordered control arms, bushings, sway bar links, and tie rods...is there a tech article?
Jim
Jared at Pelican Parts 01-14-2003 08:12 AM
Jim,
bushing overhaul tech article is in the planning stages. (I have a suspension squeak coming from somewhere, time to address that)
If you are still seeing a problem with the idle, I think you are correct in assuming the coolant temp sensor. Before the oxygen sensor has warmed up, the engine depends on the coolant temp sensor as well as the other sensors to provide the fuel injection computer with signals needed to regulate the fuel-air mixture. When the O2 sensor warms up, either by exhaust heat or heating element, it takes over control from the other sensors.
jamesthevaliant 01-22-2003 03:19 PM
Okay, Jared.......coolant temp sensor...after consulting the Good Book, I am reading all about the check and replacement procedure for the coolant temperature sending unit. Is this what you are refering to as the coolant temp sensor?
Jared at Pelican Parts 01-22-2003 03:20 PM
yes, exactly. It should be located in the thermostat housing.
Peter Mathern 01-28-2003 08:18 AM
idle problems
My idle control valve was intermittent on my '89 325is, and caused similar problems. On some cold days, you could hear the valve trying to work, but you couldn't feel it vibrating. Tapping on it would get it working again and the car would work normally. I replaced the valve, but it sounds like some people have had good results cleaning theirs.
Jared at Pelican Parts 01-31-2003 03:50 PM
You may also want to try cleaning out the idle control valve. From what i've heard, BMW dealers would take the valves and spray them full of brake cleaner, then drain it out until the cleaner appears clear. Basically, the valve eventually gets clogged up with oil mist residue from the valve cover breather hose. Sometimes, this impedes the valve from opening and closing. Just be sure to let the valve dry out before re-installing. Some brake cleaners contain zylene or naptha which are both extemely flammable. Some even contain ether in the propellant, which is also used as starting fluid in carbureated cars. You dont want this stuff going down into the cylinders. it would be very bad for the engine.
jamesthevaliant 02-03-2003 08:55 AM
Jared, I have already cleaned out the ICV, but I used a carb cleaner. This didn't seem to help much. I am picking up my car today from the mechanic.....he found a used ECU to fix my little electrical mishap. I also had him test the coolant temp sensor while he had it, and it was bad. Ispoke with him this morning, and he said that after changing that sensor, the car runs and idles wonderfully. Some good news at last! I will let you know as soon as I get it back and drive it.
Jared at Pelican Parts 02-03-2003 08:56 AM
Glad I could help.
jamesthevaliant 02-05-2003 05:45 PM
Jared.......many thanks. New coolant temp sensor installed- problem solved. Jim-
Jared at Pelican Parts 02-06-2003 07:46 AM
I just finished a tech article on how to chenge it out yourself. Im sorry I didnt get it to you quicker.
jamesthevaliant 02-07-2003 09:29 AM
I would have done it myself, but my car was already in the shop having neurosurgery, so.........
Jared at Pelican Parts 02-07-2003 09:32 AM
You know, when you think baout it, neurosurgery is not all that different from working on cars, just that a surgeon has to keep it running while he's working on it. Someday in the future, Im sure we will have DIY brain surgery. just like those people who believe in trepanation.
jamesthevaliant 02-09-2003 11:57 AM
don't go drilling any holes into your head just yet.....
Wayne 962 02-10-2003 12:22 PM
The coolant temp sensor made my truck run rich for the longest time. Of course, it required removal of a ton of stuff to reach it!
-Wayne
gott 02-13-2003 04:01 PM
Just a note to anyone reading the thread. Some of the items replaced, like the O2 sensor, should give a check engine light on this car.
--Gregg
bar1202 03-03-2003 07:27 PM
Well I could be wrong but sound to me that you could have a bad head temp. sensor.
