Additional Air Valve Slide e30 320 jetronic
hello someone can you indicate with certainty whether the valve is fully closed when the water heating?
thank you
hallo, jemand kann Ihnen mit Sicherheit angeben, ob das Ventil vollständig geschlossen ist, wenn das Wasser erhitzt?
dank
buongiorno qualcuno saprebbe indicarmi con certezza se la valvola deve chiudere totalmente quando si riscalda l'acqua?
good morning
I think I have a problem with the valve in the picture
mine did not close properly, leaving a 3-4 mm space.
it's normal
or it must completely shut down when the car is hot?
thank you
grazie
dank dank dank
thanks thanks thanks
my bmw is E30 320 1984 LE JETRONIC
Old 07-06-2016, 07:51 AM
allenwilson33's Avatar
My 83' has K-jet, so I can't say from personal experience since I've got a cold start valve instead of an air slide valve, but I thought the 84-85 318i models had an electrically-generated version. Either way, if you want to check it, just warm up the engine, then clamp down the hose which goes to the idle bypass screw housing, and if it the engine stalls a little, you know that valve is bad. Not sure if it needs to completely close or not, however. Hope that helps.
Old 07-07-2016, 09:39 PM
thanks for the reply
I bypassed the idle pipe, excluding the valve, the engine responds better, and rides down direct to 850 rpm, perfect, after I noticed that about 15 seconds, the car lurches about 500 rpm, is this normal?
thank you
you know the piece in the picture?
thank you
anyone knows the precise operation and what is it, and how you adjust this piece? thanks
Old 07-09-2016, 01:36 AM
