I have an E36 92' 325i. How do I gain access to change the lights behind my speedometer and/or the directional signals and warning lights? Is the clear glass gauge cover removable with the two front screws or do I have to remove the lower dash pad and crawl underneath?
Author of "101 Projects"
Hi there. This is a good question. The gauge cluster is removable from the dash by removing the two screws at the top inside of the dash area, and then pulling out the unit. Depending upon which steering wheel you have, you may need to remove or reposition the wheel to get the gauge cluster out.
It's not a difficult job - just make sure that you make a note of which bulbs are out before you remove the unit, as it can be difficult to tell which ones are which. Hey, where are you located in LI? I grew up in Oceanside! -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
