Mr.P (guest)
Guest
Posts: n/a
BMW X5 3.0i M54 Vanos seals is new, cps intake is new and solenoid new, and still a loss of power in 5th gear little bit hard shifting but better then before on power and shifting, got code 67 DME: VANOS inlet camshaft, end position not reached. can it be the exhaust cps? or the vanos seals that have an brake in period?
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series VANOS Oil Line and Solenoid Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 11-23-2016, 07:08 AM
Nick at Pelican Parts's Avatar
Unlikely. it would set a different fault if the sensor was the issue. I would assume the timing is off due to VANOS repair or worn VANOS. Seals have no break in period.
- Nick
