Drops (guest)
Guest
Posts: n/a
Hi. I'm driving a 2003 e39 525i in South Africa. the dives nice after a short distance trip and then starts to sputter and loose speed no matter how hard I press on the accelerator pedal, and petrol fumes is strong I cant drive with open windows. What could be the problem?
This post was auto-generated based upon a question asked on our tech article page here: BMW E30/E36 Fuel Filter Replacement | 3-Series (1983-1999) | Pelican Parts DIY Maitenance Article
Old 02-06-2017, 06:52 AM
Nick at Pelican Parts's Avatar
Is the check engine light on or flashing when the problem is present? Sounds like an engine misfire. I would check spark, fuel and compression on all cylinders.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Plug into your DME and read what faults are present. Right now, it could be more than a few things - such as vacuum leak, fuel issue, etc.
Old 02-06-2017, 11:59 AM
