vince (guest)
Guest
Posts: n/a
I am replacing the ancient rubber brake hoses on my 1990 325i e30 with the steel braided set PLB-323-106D. Is it recommended to use any type of lock-tite or anti-seize on the threads when installing if so, what would you recommend? Or is it best to just clean the threads if so, what to clean with / what not to clean with?
This post was auto-generated based upon a question asked on our tech article page here: BMW E30/E36 Brake Line Replacement | 3-Series (1983-1999) | Pelican Parts DIY Maitenance Article
Old 03-13-2017, 05:37 AM
Nick at Pelican Parts's Avatar
No threadlocker is needed. You can use brake cleaner spray and a wire brush to clean the threads. Ne sure to plug the brake line before cleaning to prevent debris from entering the hydraulic system.
- Nick
