ChowderHead's Avatar
Send a message via AIM to ChowderHead
Dealership service codes
The guy at the dealership gave me a vehicle history print out of my car , since I purchased a used certified M3.The print out shows me every time the car was in for servicing or whatever else. It also lists the mileage and date when work was performed. I was curious if there is a web sight where I can look up the the BMW defect codes that the dealership uses. They are mostly ten digits in length.and don't seem to jive with anything that shows up on the diagnostic chart that I received when purchasing a reset tool. If anyone can shed some light here I would love to hear from you.
Old 01-04-2003, 07:12 PM
Author of "101 Projects"
Wayne 962's Avatar
You might want to check this out:
http://www.pelicanparts.com/bmw/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm
The Motronic codes are actually four digits, and don't correspond to anything that is on the Peake tool. I think they used their own codes to limit the size of the display to two digits...
-Wayne
Old 01-04-2003, 10:40 PM
i can help you if you pm me the codes. those that start with 34 are brake related, 85 is oil change or inspection related, 61 is electrical. pm me.
shaun
ps. he is talking about the warrenty codes that are 10 digits, not dme codes.
1991 nissan 240sx
sr20det cp pistons, eagle rods, 740cc inj, k3t turbo, jwt s4 cams, lots of duct tape, GReddy headgasket
Old 01-13-2003, 02:49 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I've been looking for this info too. My BMW guy can only tell me where the service was performed by reading the codes, not the actual work done.
Old 01-14-2003, 02:40 PM
Thanks for the response Shaun, hope you can help. It's kinda long but here is the list of codes:
7211077900
1711075900
3241124800
6131181400
6321061200
51471001BI
6325051200
85990091SP
34000077SP
85990092SP
0065370100
2511032300
32330603WR
6761011200
0012270100
6762011100
85990089SP
If you know all this crap,"YOUR THE MAN"!
Thanks,
Richard (aka Chowderhead)
Old 01-14-2003, 06:36 PM
I'll call my BMW guy and see what he says.
Old 01-15-2003, 10:21 AM
check your pm's
20psi
1991 nissan 240sx
Old 01-20-2003, 09:16 AM
didnt get your PM, 20psi
Old 01-20-2003, 03:43 PM
i sent a pm to the other guy. i think i got him helped out somewhat.
1991 nissan 240sx
Old 01-21-2003, 02:10 PM
Sounds good. Im still trying to find a source so i can get those codes all figured out.
Old 01-21-2003, 03:04 PM
