E30 Idle speed troubleshooting
Hi pelican, Ive got an 89 325is. Once the car gets up to temp it surges randomly when idling, and the throttle sticks open slightly when i clutch in. Would this be a sticky idle control valve or a bad throttle switch?
__________________ This post was auto-generated based upon a question asked on our tech article page here: BMW E30 3-Series Idle Speed Troubleshooting (1983-1991) | Pelican Parts DIY Maintenance Article |
Likely the idle control valve, but make sure that your throttle linkages are free to move.
- Casey |
If your idle control valve is faulty, here is a new one: 1989 BMW 325is Base Coupe - Idle control valve
Page 27 of section 6 Bentley gives 6 items to check. With me its always a vacuum leak. A new valve cover gasket & tighten all the hose clamps may fix it.
Tom |
| All times are GMT -8. The time now is 06:22 AM. |
