Brian (guest)
Guest
Posts: n/a
I pulled the slave cylinder and the plunger was covered in thick black grime. Is there a way to clean the cavity where the new one goes and is the black grime and indication of something worse??
This post was auto-generated based upon a question asked on our tech article page here: BMW E30/E36 Clutch Slave Cylinder Replacement | 3-Series (1983-1999) | Pelican Parts DIY Maitenance Article
Old 04-14-2017, 06:26 AM
Nick at Pelican Parts's Avatar
Black grime could be from a fluid leak that is now covered in clutch dust. If your clutch pedal is high, the clutch may be worn.
- Nick
