Haneif (guest)
Guest
Posts: n/a
Great write up, thank you! I have a question regarding the centering sleeve that is located inside the drive shaft. I replaced it but I damaged the outside of the new sleeve putting it in takes a lot of force. But since only the inside of the centering sleeve comes in contact with anything would it be alright to still use? Or would you recommend replacing it again? In the picture you can see the outside edge of the sleeve is deformed, but the inside is fine. Your advice is much appreciated, thank you!
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Driveshaft Flexdisc - Guibo Replacement(1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 04-26-2017, 06:44 AM
Nick at Pelican Parts's Avatar
I would replace that bushing, best to have a good one in there. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
