Luis M3 (guest)
Guest
Posts: n/a
Hi, I have an 96´ M3 with S50B32 that I redone the vanos seals and anti rattle kit from Beisan, full revision with new oil and filters, chain tensioners...
After 1000km I am getting a knock from vanos only warmed up. I mesured the vanos oil pressure and is 105 Bar but drops to 100 Bar with the knock. When cold the engine is without any strange noise and very smooth.
What can be causing this warmed up noise from vanos related to oil pressure??
Thanks in advance
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series VANOS Oil Line and Solenoid Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 05-24-2017, 05:10 AM
Nick at Pelican Parts's Avatar
100 bar at idle is OK. The noise could be a faulty actuator,or timing chain components.
- Nick
Luis M3 (guest)
Guest
Posts: n/a
Thanks for quick reply!
Is really a solid knock inside vanos, not timing chain related. There are no codes or errors with diagnostic. The engine is smooth and full of power. Also vanos works perfectly. Only the knock when warmed up. I connected the pressure gauge to vanos and knock is related to oil pressure. Sorry for asking, but what is the actuator?
Old 05-24-2017, 06:54 AM
The actuator is the VANOS unit.
if knocking, that unit is likely faulty. You have the correct pressure from your test results.
- Nick
