Murph (guest)
Guest
Posts: n/a
I have a 1997 bmw 318ti and I'm running in to an issue with the car not wanting to rev over 3000 2000rpms. I've replace the crank sensor with an O.E.M sensor and checked for broken vacuum lines. Cleaned the MAF sensor. I'm about to replace the cam sensor but if that does not solve the issue do you have any ideas? Also have a new fuel pump and fuel filter.
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Camshaft Position Sensor Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 07-18-2017, 09:55 AM
Nick at Pelican Parts's Avatar
Does it lack power / running choked up? Or is it limited by the DME, revs stop building.
- Nick
