Send a message via ICQ to fred hannah
323is door question
need some help here guys. the(inside) door handle on the driver side is loose.it is obviously fastened inside the door panel(no visible fasteners). how do i remove the door panel without damaging it?the fastener that holds the handle is just loose,not broke off. any help getting inside the door would be great
fred
Old 01-31-2003, 06:56 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
To remove the door panel, first pry off the inner door handle frame. Simply pull it to the rear and it will come off. Next, remove the mirror switch by prying it out of its holder. Now, unscrew the door lock push buttons at the rear of the doors. Remove the plugs in the armrest, and remove the screws underneath. Now remove the door panel by pulling the panel outward at the lower edge of the door. Slowly work your way around the perimeter of the door panel until you have released all the clips holding the panel to the door. Now remove the door panel and check the bolts that hold the door handle to the door.
Old 01-31-2003, 04:42 PM
