-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   What tech articles would you all like to see? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/97093-what-tech-articles-would-you-all-like-see.html)
jim72911t 03-15-2003 10:11 PM
What about control arm replacement? Steering box rebuild? I track my car and these need to be done before the next outing. (no pressure ;) )
Thanks,
Jim
Jared at Pelican Parts 03-17-2003 09:25 AM
Controla arm replacement is done, albeit no pictures. email me and I'll send it to you. It is a rough draft im sure I will change a few things. For instance, I am designing a tool that will allow you to install the rear control arm mounts without headaches. Putting those on had my anger factor peaked at 11. Let me tell you that human hands hitting forged steel at high velocity is not a good idea.
daves325 03-17-2003 10:43 PM
Jared....
You can tackle the rear wheel bearing changout if ya want......As you know I just did one...the wrong way..haha....so I learned the hard way also.
I will say however that it is a several step process for reassembly and one does need "the tool"...($250.00) unless you remove the entire swing arm ass'y & take it to a BMW dealer or shop..
Dave
Dub-Dub 03-20-2003 01:35 PM
Can I second the valve adjustment! For something that is supposed to be done yearly, a step by step would be great. Plus control arms and other rubber parts... what can be done by a shadetree, what can not... rear axles, maybe?
Javier at Pelican Parts 03-20-2003 02:12 PM
Jared, i've got a Viking gs2003 commericail range with 8 burners 2 stoves, right know its got a max output of 35000 btus but this is capable of 62000 you got a tech article on how to re-build regulater valve with out blowing up my house? just thoght i'd ask.
Jared at Pelican Parts 03-20-2003 02:16 PM
For some reason the idea of gas and Javier together is not very appealing.
daves325 03-20-2003 02:24 PM
A viking...hmmm Javier must have a mansion In the hills to go with it.
Javier at Pelican Parts 03-20-2003 02:26 PM
Nope, look at my avatar, professional chef by trade and passion.
daves325 03-20-2003 07:03 PM
Ahhhhhhhh ok...what times brunch?
Javier at Pelican Parts 03-21-2003 09:10 AM
Well lets see, I ve got 8 fresh lobsters coming in tomorrow from Maine, for my bros b-day, lobster omlets for Sunday sounds pretty good.
Jared at Pelican Parts 03-21-2003 09:11 AM
I want an lobster omlette!
Jared at Pelican Parts 03-21-2003 01:48 PM
Getting back on topic here,
this is what i have planned in the immediate future
- Control arm replacement along with drop links and sway bar bushings.
- S.I. Board battery replacement and relocation
- On board Diagnostics
- Rear trailing arm replacement and bushing R+R
Plus a whole lot more, chances are i have a rough draft of whatever you may need. Email me at jared@pelicanparts.com if you want a copy.
Jeff at WallWerks 03-21-2003 01:52 PM
sounds like good stuff! Say, Jared, didnt you do a valve adjustment article a while back?
thanks
jeff
Jared at Pelican Parts 03-21-2003 01:52 PM
Yeah,
do you need that one, Jeff?
Jeff at WallWerks 03-21-2003 01:54 PM
At your convenience, im not in a big hurry, but want
to do it before I move in June.
thanks
Jared at Pelican Parts 03-21-2003 01:55 PM
It's already online here..
http://www.pelicanparts.com/bmw/techarticles/E30-Valve_Adjust/E30-Valve_Adjust.htm
blw 03-27-2003 05:40 PM
I'd like to 4th (or whatever) the timing belt. I have to do one for an E30 and also for an E28 fairly soon...
