-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Question on BMW 3-Series E36 O2_Sensor (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/974706-question-bmw-3-series-e36-o2_sensor.html)
jhendez (guest) 10-21-2017 08:34 AM
Hi there. I have a 325is E36, 1993, AT and an issue that sometimes drives me crazy. Once I start the car and it reaches the proper temperature, the motor runs normal, but, for example if I parked for several minutes or let say I got stuck in traffic, then the CHECK ENGINE LIGHT turns on and the transmission goes to a emergency shift. To "fix" that I turn off the car, and then start the engine again and is back to normal. Then while I´m driving, its ok but if I stopped for few minutes the problem comes back. I alreadey changed the O2 Sensor. Thanks
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Oxygen Sensor - O2 Sensor - Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 10-21-2017 08:34 AM
What fault codes are stored in the engine and transmission?
- Nick
jhendez 11-05-2017 07:19 AM
- Nick
1216. I have to mention that I already changed the TPS.
tomgalloway1 11-08-2017 05:54 AM
On my (bastard) '89 325is with a 2.7 from an '84 and top end from a '91 the light comes on like you describe - if I rev to above 2k. for a few seconds it goes away - also my AF has been clicked up 5 notches.
To bad about the trans. issue ( I would look to remove a wire from ( whatever ? ))
I always thought it was the O2 also - to rich at low rpm.
Tom
