View Single Post
beepbeep beepbeep is online now
beepbeep's Avatar
88 has stock 4-speed and wire-operated clutch. Try to adjust the clutch first. 2:nd gear synchro is engine-out job though. You might as well do the clutch when everything is out. Chatter is probably rubber-damped disc job cracking. Replace it with spring-damped one.
Thank you for your time,
Old 10-11-2007, 12:47 AM
