Originally Posted by 74goldtarga
How do I verify that I do in fact have the 24pin box (my car was modded when I got it so I just want to be safe)?
Best way is to simply open the DME and take a look. Follow the LR Chip change guide link I posted in the beginning.
Based on what I'm reading here you need a piggyback to properly run an MAF or MAP.
Not 100% necessary, since with TunerPro you have direct access to the tables... But that said, a piggy-back is great for making changes without the laptop, and for helping with MAF conversion.
How complicated is the installation of a Piggyback for someone who would be afraid to splice wires.
It is quite easy, and I'm sure there is a guide somewhere. Usually it is only about 5-6 wires.
Rogue I see that you are using a MAP sensor and some kind of piggyback to get that to work with the Motronic/TunerPro/Ostrich combo is that right?
My setup is unique, and helps me make quick changes and then test them. Really nearly any piggyback will be fine, Vic can probably help you out with that...
Does the datalogging come from the Ostrich device and the Wideband? Vic do you sell a piggyback that goes with the Sci-Vision MAF? Thanks.
My current datalogging comes from my piggyback... I'm working on a DME native logging setup, but not done with it yet.
-Rogue
